Samsung Galaxy Note Edge Battery Replacement
  1. Samsung Galaxy Note Edge Battery Replacement, Battery: step 1, image 1 of 1
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Note Edge Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Note Edge Battery Replacement: step 2, image 3 of 3
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
2 other people completed this guide.
Cal Poly, Team S22-G6, Maness Spring 2018 Member of Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
4 Members
10 Guides authored
1 Guide Comment
La batterie a une faible autonomie et se dégrade vite, en bombant souvent. Déjà 3 batteries remplacées sans succès. Que faire?
ikomboji bofumbo - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,336
