Samsung Galaxy Note Edge Display Assembly Replacement
Video Overview
  1. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Battery: step 1, image 3 of 3
    • Switch off the device.
    • Remove the back cover and the battery.
  2. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Rear Housing: step 2, image 3 of 3
    • Remove the Memory card, the SIM card and the S Pen.
    • Remove the screws by using Screwdriver Phillips #00
    • With a plastic opening tool emove the Back Frame.
  3. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 1: step 3, image 3 of 3
    • Disconnect one by one:
    • Coaxial antenna cable (x2)
    • Home Button flex cable
    • Display Flex cable
    • Stylus Sensor flex cable
    • Front Camera flex cable
  4. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Motherboard 2: step 4, image 3 of 3
    • Pry up the connector on the back of the board to release the bottom part of motherboard.
    • Gently remove the logic board.
  5. Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Test the new spare part: step 5, image 3 of 3
    • I prefer to test the new spare part before install it.
    • Transfer the Power button / Loud speaker flex cable.
    • Install the mother board.
    • Test the display.
    • To prevent damage to the put back the back frame before the test.
  6. Samsung Galaxy Note Edge Display Assembly Replacement, Check the Thermal Pads: step 6, image 1 of 1
    • Check the quality of the thermal pads (if the spare part is not original).
    • If its necessary use the thermal pads from the old assembly.
  7. Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Transfer all the parts from the old Display assembly - Part 1: step 7, image 3 of 3
    • Insert wisdom here.
  8. Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 1 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 2 of 3 Samsung Galaxy Note Edge Display Assembly Replacement, Remove the Galaxy Note Edge Charging Port Flex Assembly.: step 8, image 3 of 3
    • Remove the black Phillips screw,
    • the the charging port plate,
    • disconnect the Home buttons flex cable
    • and the coaxial antenna cable (x2).
    • Use hot air and a plastic opening tool to remove the Charging Port flex assembly.
  9. Samsung Galaxy Note Edge Display Assembly Replacement, Reassembling: step 9, image 1 of 1
    • To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
ZFix
196,124 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
331 Members
1,458 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 37
All Time: 2,442
