Samsung Galaxy Note II Front Facing Camera Assembly Replacement
  1. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Stylus: step 1, image 2 of 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 3, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, MicroSD Card: step 4, image 3 of 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Battery: step 5, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 6, image 1 of 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Midframe: step 7, image 1 of 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 8, image 3 of 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 9, image 3 of 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 10, image 2 of 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 11, image 2 of 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 12, image 2 of 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 13, image 2 of 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 14, image 2 of 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Front Facing Camera Assembly Replacement, Front Facing Camera Assembly: step 15, image 1 of 1
    • Remove the 3mm Phillips #00 screw from the front-facing camera bracket.
  16. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 16, image 1 of 1
    • Remove the front-facing camera bracket.
  17. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 17, image 1 of 1
    • Use the flat end of a spudger to disconnect the front-facing camera connector.
  18. Samsung Galaxy Note II Front Facing Camera Assembly Replacement: step 18, image 1 of 1
    • Remove the front-facing camera.
13 other people completed this guide.
Sam Goldheart
467,548 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,059 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 11,804
