Samsung Galaxy Note II Midframe Replacement
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Stylus: step 1, image 2 of 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 3, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 3 of 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Battery: step 5, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: step 6, image 1 of 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: step 7, image 1 of 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Midframe Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 8, image 3 of 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Midframe Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 9, image 3 of 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 10, image 2 of 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Midframe Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 11, image 2 of 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 12, image 2 of 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 13, image 2 of 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Midframe Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 14, image 2 of 2
    • Lift the display assembly out of the midframe.
52 other people completed this guide.
Sam Goldheart
475,193 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,818 Guides authored
5 Guide Comments
There are two hidden clips near battery housing. One inside in upper part of battery housing and the second below battery near antenna.
milankerslager - Reply
How do I fix the glass
Nena Summer Perez - Reply
Very good job you are doing. It is very helpful to us. Thanks for sharing your knowledge to the people my wishes are with you god bless you.
HARDIK PANCHOLI - Reply
very very very useful brother
Arunkrishna T H - Reply
Brilliant Thanks.
michaeleggar6 - Reply
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 58
All Time: 30,847
