Samsung Galaxy Note II Speaker Enclosure Replacement
  1. Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: step 1, image 2 of 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Speaker Enclosure Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 3, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: step 4, image 3 of 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: step 5, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Speaker Enclosure Replacement: step 6, image 1 of 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Speaker Enclosure Replacement, Midframe: step 7, image 1 of 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Speaker Enclosure Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 8, image 3 of 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Speaker Enclosure Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Speaker Enclosure Replacement: step 9, image 3 of 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Speaker Enclosure Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement: step 10, image 2 of 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Speaker Enclosure Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement: step 11, image 2 of 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Speaker Enclosure Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement: step 12, image 2 of 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Speaker Enclosure Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement: step 13, image 2 of 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Speaker Enclosure Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Speaker Enclosure Replacement: step 14, image 2 of 2
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Speaker Enclosure Replacement, Speaker Enclosure: step 15, image 1 of 1
    • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
  16. Samsung Galaxy Note II Speaker Enclosure Replacement: step 16, image 1 of 1
    • Remove the speaker enclosure.
9 other people completed this guide.
Sam Goldheart
471,438 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
One Comment
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 13,875
