Samsung Galaxy Note SIM Card Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Samsung Galaxy Note SIM Card Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy Note SIM Card Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy Note SIM Card Replacement, Battery: step 1, image 3 of 3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note SIM Card Replacement: step 2, image 1 of 1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note SIM Card Replacement: step 3, image 1 of 1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note SIM Card Replacement, SIM Card: step 4, image 1 of 1
    • Pull out the (white and blue) SIM card directly above the empty battery slot.
David Ritter
758 Reputation
6 Guides authored
Cal Poly, Team 3-45, Amido Spring 2013 Member of Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,429
