Samsung Galaxy Note Speaker Enclosure Replacement
  1. Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Stylus: step 1, image 2 of 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Speaker Enclosure Replacement: step 3, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 3, image 2 of 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Speaker Enclosure Replacement, Battery: step 4, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, Battery: step 4, image 2 of 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement, MicroSD Card: step 5, image 3 of 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Speaker Enclosure Replacement: step 6, image 1 of 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: step 7, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement, SIM Card: step 7, image 2 of 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Speaker Enclosure Replacement: step 8, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 8, image 2 of 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Speaker Enclosure Replacement, Midframe: step 9, image 1 of 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Speaker Enclosure Replacement: step 10, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 10, image 2 of 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 11, image 3 of 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 1 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 2 of 3 Samsung Galaxy Note Speaker Enclosure Replacement: step 12, image 3 of 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Speaker Enclosure Replacement: step 13, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 13, image 2 of 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Speaker Enclosure Replacement, Speaker Enclosure: step 14, image 1 of 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  15. Samsung Galaxy Note Speaker Enclosure Replacement: step 15, image 1 of 2 Samsung Galaxy Note Speaker Enclosure Replacement: step 15, image 2 of 2
    • Remove the speaker enclosure from the display assembly.
6 other people completed this guide.
Sam Goldheart
467,548 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,060 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 7,207
