Samsung Galaxy Note20 Battery Replacement
  1. Samsung Galaxy Note20 Battery Replacement, Heat the rear cover: step 1, image 1 of 1
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
  2. Samsung Galaxy Note20 Battery Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy Note20 Battery Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy Note20 Battery Replacement, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 Battery Replacement, Begin to cut the adhesive: step 3, image 1 of 3 Samsung Galaxy Note20 Battery Replacement, Begin to cut the adhesive: step 3, image 2 of 3 Samsung Galaxy Note20 Battery Replacement, Begin to cut the adhesive: step 3, image 3 of 3
    • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Samsung Galaxy Note20 Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Samsung Galaxy Note20 Battery Replacement, Cut along the perimeter of the rear cover: step 4, image 3 of 3
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
  5. Samsung Galaxy Note20 Battery Replacement, Remove the rear cover: step 5, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Remove the rear cover: step 5, image 2 of 2
    • Lift the rear cover straight up to remove it.
  6. Samsung Galaxy Note20 Battery Replacement, Remove the motherboard shield: step 6, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
  7. Samsung Galaxy Note20 Battery Replacement: step 7, image 1 of 3 Samsung Galaxy Note20 Battery Replacement: step 7, image 2 of 3 Samsung Galaxy Note20 Battery Replacement: step 7, image 3 of 3
    Buy
    • Use a pair of tweezers to lift up and flip back the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
  8. Samsung Galaxy Note20 Battery Replacement, Disconnect the battery: step 8, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Disconnect the battery: step 8, image 2 of 2
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. Samsung Galaxy Note20 Battery Replacement, Disconnect the wireless charging coil: step 9, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Disconnect the wireless charging coil: step 9, image 2 of 2
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
  10. Samsung Galaxy Note20 Battery Replacement, Remove the wireless charging coil: step 10, image 1 of 3 Samsung Galaxy Note20 Battery Replacement, Remove the wireless charging coil: step 10, image 2 of 3 Samsung Galaxy Note20 Battery Replacement, Remove the wireless charging coil: step 10, image 3 of 3
    • Grip the motherboard shield with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the device with light adhesive.
    • Remove the wireless charging coil.
  11. Samsung Galaxy Note20 Battery Replacement, Unscrew the loudspeaker: step 11, image 1 of 1
    • Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
  12. Samsung Galaxy Note20 Battery Replacement, Remove the loudspeaker: step 12, image 1 of 3 Samsung Galaxy Note20 Battery Replacement, Remove the loudspeaker: step 12, image 2 of 3 Samsung Galaxy Note20 Battery Replacement, Remove the loudspeaker: step 12, image 3 of 3
    Buy
    • Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
    • Use the spudger to pry up and detach the loudspeaker from the frame.
    • Use a pair of tweezers to lift and remove the loudspeaker.
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
  13. Samsung Galaxy Note20 Battery Replacement, Disconnect the interconnect cables: step 13, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Disconnect the interconnect cables: step 13, image 2 of 2
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
  14. Samsung Galaxy Note20 Battery Replacement: step 14, image 1 of 2 Samsung Galaxy Note20 Battery Replacement: step 14, image 2 of 2
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
  15. Samsung Galaxy Note20 Battery Replacement: step 15, image 1 of 2 Samsung Galaxy Note20 Battery Replacement: step 15, image 2 of 2
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
  16. Samsung Galaxy Note20 Battery Replacement: step 16, image 1 of 2 Samsung Galaxy Note20 Battery Replacement: step 16, image 2 of 2
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
  17. Samsung Galaxy Note20 Battery Replacement, Disconnect the display cable: step 17, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Disconnect the display cable: step 17, image 2 of 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
  18. Samsung Galaxy Note20 Battery Replacement, Move the cables: step 18, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Move the cables: step 18, image 2 of 2
    • Flip the secondary interconnect cable away from the battery.
    • The secondary interconnect cable is still attached to the phone by a ribbon cable. You only need to move the cable enough to access the battery.
    • Do not bend the ribbon cables more than necessary. Excessive bending may damage the cables.
  19. Samsung Galaxy Note20 Battery Replacement: step 19, image 1 of 3 Samsung Galaxy Note20 Battery Replacement: step 19, image 2 of 3 Samsung Galaxy Note20 Battery Replacement: step 19, image 3 of 3
    • Bend the main interconnect cable back so you can access the battery.
    • Bend the display cable back and out of the way.
  20. Samsung Galaxy Note20 Battery Replacement, Apply isopropyl alcohol: step 20, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Apply isopropyl alcohol: step 20, image 2 of 2
    • Apply 1-2 drops of high-concentration (90% or higher) isopropyl alcohol to the open spaces in each corner of the battery.
    • Using too much alcohol can damage the display.
    • Wait two minutes for the isopropyl alcohol to weaken the adhesive underneath the battery.
  21. Samsung Galaxy Note20 Battery Replacement, Remove the battery: step 21, image 1 of 2 Samsung Galaxy Note20 Battery Replacement, Remove the battery: step 21, image 2 of 2
    • Apply a suction cup to the center of the battery.
  22. Samsung Galaxy Note20 Battery Replacement: step 22, image 1 of 2 Samsung Galaxy Note20 Battery Replacement: step 22, image 2 of 2
    • Pull up on the suction cup with a steady force to create a gap between the bottom edge of the battery and the frame.
    • Take care not to bend the battery—a bent battery may leak dangerous chemicals or cause a thermal event.
    • If the battery does not appear to be separating from the frame, apply a few more drops of isopropyl alcohol and wait two minutes before trying again.
    • The adhesive underneath the battery is strong. You might need to apply isopropyl alcohol and pull up on the suction cup multiple times to loosen the battery.
  23. Samsung Galaxy Note20 Battery Replacement: step 23, image 1 of 2 Samsung Galaxy Note20 Battery Replacement: step 23, image 2 of 2
    • Insert the point of an opening pick into the gap created between the bottom edge of the battery and the frame.
    • Push the pick under the battery to cut through the adhesive and detach the battery from the frame.
    • Don't insert the opening pick more than halfway to avoid damaging the fingerprint sensor underneath the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  24. Samsung Galaxy Note20 Battery Replacement: step 24, image 1 of 1
    • Pull up on the suction cup to remove the battery.
    • The battery will come out without much force once the isopropyl alcohol has adequately penetrated the battery adhesive.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • During reassembly, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
25 other people completed this guide.
Kyle Smith
50,691 Reputation
123 Guides authored
6 Guide Comments
Was ist das doch für eine Sauerei das sowas von zu verkomplizieren!Ich würde es nicht machen/versuchen!Schade Samsung!Das war mein letztes Samsung Smartphone nach gefühlten 5,6!Daumen hoch die das können!
Manfred Elsing - Reply Share
I need to order a new battery.but can't find the part number. to get the right one and size. I have a Samsung Galaxy note 20 5G Uleta
cell phone my email billycohen@hotmail.com
Thanks Billy
William Cohen - Reply Share
Just finished! Great guide. Wouldn't have attempted without such a guide.
Yarran Byrne - Reply Share
Guide was very easy to follow and made getting the battery out easy. It took more time removing the old glue off the back to reinstall new adhesive kit.
Mike - Reply Share
Thank u I am going to try this
Charles Ralston - Reply Share
Past 24 Hours: 33
Past 7 Days: 254
Past 30 Days: 957
All Time: 47,134
