Samsung Galaxy Note5 Midframe Replacement
  1. Samsung Galaxy Note5 Midframe Replacement, SIM Card Tray: step 1, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement, SIM Card Tray: step 1, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement, SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray at the top of the phone.
    • Press to eject the tray. This may require some force.
    • Remove the SIM card tray.
  2. Samsung Galaxy Note5 Midframe Replacement, S-Pen: step 2, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement, S-Pen: step 2, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement, S-Pen: step 2, image 3 of 3
    • Using your fingernail, push the S-Pen button until it clicks and pops out of the phone.
    • Remove the S-Pen.
  3. Samsung Galaxy Note5 Midframe Replacement, Rear Glass: step 3, image 1 of 1
    • If the glass back is cracked, carefully tape over the entire surface with packing tape.
    • Apply a heated iOpener to the bottom of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  4. Samsung Galaxy Note5 Midframe Replacement: step 4, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 4, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 4, image 3 of 3
    • Apply a suction cup as close as possible to the bottom edge of the phone.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup and insert an opening pick under the rear glass.
    • The rear glass very fragile and can break if you use too much force or attempt to pry with metal tools.
  5. Samsung Galaxy Note5 Midframe Replacement: step 5, image 1 of 1
    • Once the pick is in place, reheat the edge with an iOpener for another minute.
  6. Samsung Galaxy Note5 Midframe Replacement: step 6, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 6, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 6, image 3 of 3
    • Slide the pick down the bottom edge of the phone.
    • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place to prevent the adhesive from resealing, and grab another pick as you proceed to the next step.
  7. Samsung Galaxy Note5 Midframe Replacement: step 7, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 7, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 7, image 3 of 3
    • Insert another pick and slowly cut around the corner of the phone.
    • Due to the curved shape of the back, the glass is extremely fragile and prone to cracking in the corners. Be patient and reapply an iOpener if the corner feels hard to slice through.
  8. Samsung Galaxy Note5 Midframe Replacement: step 8, image 1 of 1
    • Before cutting further, apply a heated iOpener to the long edge.
  9. Samsung Galaxy Note5 Midframe Replacement: step 9, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 9, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 9, image 3 of 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
  10. Samsung Galaxy Note5 Midframe Replacement: step 10, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 10, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 10, image 3 of 3
    • Use an opening pick to cut any remaining adhesive around the edges of the glass.
    • Lift the glass and remove it from the phone.
  11. Samsung Galaxy Note5 Midframe Replacement: step 11, image 1 of 1
    Tool used on this step:
    Tesa 61395 Tape
    $5.99
    Buy
    • To reinstall the back cover:
    • Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
    • After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  12. Samsung Galaxy Note5 Midframe Replacement, Midframe: step 12, image 1 of 1
    • Remove the twenty 3.3 mm Phillips screws.
  13. Samsung Galaxy Note5 Midframe Replacement: step 13, image 1 of 3 Samsung Galaxy Note5 Midframe Replacement: step 13, image 2 of 3 Samsung Galaxy Note5 Midframe Replacement: step 13, image 3 of 3
    • Make sure you've ejected the SIM tray before performing this step.
    • Hold the midframe by the edges and lift it upwards while pushing down against the battery with one finger.
    • There is a small amount of adhesive in each corner holding the midframe to the display assembly. Apply constant force until the midframe separates.
    • Remove the midframe.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
33 other people completed this guide.
Arthur Shi
314,232 Reputation
729 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,807 Guides authored
4 Guide Comments
When I reassembled my phone, after placing the back cover. I reapplied the heat gun to activate the adhesive so it can make better contact.
ericperez10002 - Reply
Nice tips all the time updated
malik - Reply
Where to buy the middle housing?
Kam Your Favourite Nationalist - Reply
I bought mine from mentor.com. eBay would work too.
Eric Thomas -
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 41
All Time: 21,561
