Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement
Video Overview
  1. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: step 1, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: step 1, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Loudspeaker: step 1, image 3 of 3
    • Remove any SIM and SD card.
    • Remove 7x Phillips screws.
    • Use a plastic tool to disassemble the rear housing.
  2. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 2, image 1 of 1
    • The Loudspeaker is located on the rear housing..
  3. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: step 3, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: step 3, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Logic Board: step 3, image 3 of 3
    • Disconnect the LCD Display flex cable.
    • Lift up the board and disconnect the Touchscreen flex cable.
    • Now you can remove the Motherboard.
  4. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: step 4, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: step 4, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement, Touchscreen, Digitizer Glass, LCD Display: step 4, image 3 of 3
    • Warm the touchscreen to make separating the LCD Display more easy
    • For this manipulation you can use a hair drier.
    • In the four corners of LCD display there are small metal plates. Use one of them to lift a little the LCD and put the plastic tool.
    • Be careful not to break the display.
  5. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 5, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 5, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 5, image 3 of 3
    • After separating the LCD Display, again worm the Touchscreen.
    • If the glass is broken, put a transparent tape to prevent scattering.
  6. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 6, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 6, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 6, image 3 of 3
    • Use plastic tools and slowly separate the touch screen from the front bezel.
  7. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 7, image 1 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 7, image 2 of 3 Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 7, image 3 of 3
    • If the new spare part has come without adhesive tape. you must put.
    • Reassemble your device, follow these instructions in reverse order.
  8. Samsung Galaxy Pocket Neo S5310 LCD Display, Touch screen Replacement: step 8, image 1 of 1
    • Did you do it successfully?
3 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 7,496
