Samsung Galaxy Prevail 2 Battery Replacement
  1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 1 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 2 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: step 1, image 3 of 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 1 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 2 of 3 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: step 2, image 3 of 3
    • Gently pull the battery out of the phone.
4 other people completed this guide.
Alexandra Hernandez
741 Reputation
3 Guides authored
USF Tampa, Team 14-4, Leahy Fall 2014 Member of USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Members
5 Guides authored
3 Comments
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
lindabuhl5729 - Reply
Mine doing the same
Chuck Slagel - Reply
"To reassemble your device, follow these instructions in reverse order" seriously?! I mean even an idiot should know that!
illy - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,903
