Samsung Galaxy Prevail 2 Vibrator Replacement
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: step 1, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: step 1, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: step 1, image 3 of 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: step 2, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: step 2, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: step 2, image 3 of 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: step 3, image 1 of 2 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: step 3, image 2 of 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: step 4, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: step 4, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: step 4, image 3 of 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: step 5, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: step 5, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: step 5, image 3 of 3
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: step 6, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: step 6, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: step 6, image 3 of 3
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: step 7, image 1 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: step 7, image 2 of 3 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: step 7, image 3 of 3
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: step 8, image 1 of 1
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
5 other people completed this guide.
Garrett Bowleg
469 Reputation
2 Guides authored
USF Tampa, Team 14-4, Leahy Fall 2014 Member of USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,041
