Samsung Galaxy R Motherboard Replacement
  1. Samsung Galaxy R Motherboard Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy R Motherboard Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy R Motherboard Replacement, Rear Case: step 1, image 3 of 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Motherboard Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy R Motherboard Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy R Motherboard Replacement, Battery: step 2, image 3 of 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Motherboard Replacement, Screws: step 3, image 1 of 2 Samsung Galaxy R Motherboard Replacement, Screws: step 3, image 2 of 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Motherboard Replacement, Bottom Panel: step 4, image 1 of 3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: step 4, image 2 of 3 Samsung Galaxy R Motherboard Replacement, Bottom Panel: step 4, image 3 of 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Motherboard Replacement, Top Panel: step 5, image 1 of 3 Samsung Galaxy R Motherboard Replacement, Top Panel: step 5, image 2 of 3 Samsung Galaxy R Motherboard Replacement, Top Panel: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to grasp the circular silver metal piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Motherboard Replacement, Remove Motherboard: step 6, image 1 of 1
    • If you want to replace motherboard, gently pull motherboard from the back of the phone.
    • The parts indicated in red color are attached by adhesive to the back of the phone, so more force will be necessary to remove these areas.
3 other people completed this guide.
Keon Horahan
841 Reputation
6 Guides authored
Clemson, Team 3-3, Benson Fall 2014 Member of Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 1,829
