Samsung Galaxy S Blaze Motherboard Replacement
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: step 2, image 1 of 1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: step 3, image 1 of 2 Samsung Galaxy S Blaze Motherboard Replacement: step 3, image 2 of 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: step 4, image 1 of 1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy S Blaze Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy S Blaze Motherboard Replacement: step 5, image 3 of 3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: step 6, image 1 of 1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 other people completed this guide.
Rene Bolanos
435 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 875
