Samsung Galaxy S Blaze SD Card Slot Cover Replacement
  1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement, SD Card Slot Cover: step 1, image 1 of 1
    • Make sure the device is powered off and not plugged into a power source.
    • Remove the back plate to reveal the battery.
  2. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 2, image 1 of 1
    • Use a spudger or your fingers to remove the battery from the phone.
  3. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 3, image 1 of 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
  4. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 4, image 1 of 1
    • Use the blue plastic opening tool to gently pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 5, image 1 of 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: step 5, image 2 of 2
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 other people completed this guide.
Rene Bolanos
435 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 396
