Samsung Galaxy S II T989 Front Camera Replacement
  1. Samsung Galaxy S II T989 Front Camera Replacement, Rear Cover: step 1, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Rear Cover: step 1, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Rear Cover: step 1, image 3 of 3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Front Camera Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Battery: step 2, image 3 of 3
    • Turn off the phone before removing battery.
    • The battery can be removed from the phone by applying an upwards pressure to the bottom right edge of the battery, as indicated by the red rectangle.
    • After the battery starts to lift upwards, use your hand to hold and remove it.
  3. Samsung Galaxy S II T989 Front Camera Replacement, SIM Card: step 3, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, SIM Card: step 3, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, SIM Card: step 3, image 3 of 3
    • The SIM card is the small white rectangle located in the red rectangle.
    • To remove the SIM card, press down on the card and slide it to the left, until it no longer is in contact with the metal.
  4. Samsung Galaxy S II T989 Front Camera Replacement, Media Card: step 4, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Media Card: step 4, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Media Card: step 4, image 3 of 3
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
  5. Samsung Galaxy S II T989 Front Camera Replacement, Inner Plate: step 5, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Inner Plate: step 5, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Inner Plate: step 5, image 3 of 3
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  6. Samsung Galaxy S II T989 Front Camera Replacement: step 6, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement: step 6, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement: step 6, image 3 of 3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  7. Samsung Galaxy S II T989 Front Camera Replacement, Motherboard: step 7, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Motherboard: step 7, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement, Motherboard: step 7, image 3 of 3
    • The motherboard holds many delicate components, improper handling can result in the destruction of these components.
    • To remove the motherboard, first undo the three tabs, indicated by the red outlines, using either a small flat-head screwdriver or your thumbnail.
    • In addition to the three at the top of the motherboard, there is a fourth tab at the bottom of the phone that will need to be opened as well.
  8. Samsung Galaxy S II T989 Front Camera Replacement: step 8, image 1 of 2 Samsung Galaxy S II T989 Front Camera Replacement: step 8, image 2 of 2
    • After all the tabs are unplugged, carefully apply pressure to the edges of the motherboard and lift upwards.
    • If the motherboard does not lift up, you may need to wiggle it left and right to free the corners from the areas where the case screws were placed.
  9. Samsung Galaxy S II T989 Front Camera Replacement, Front Camera: step 9, image 1 of 2 Samsung Galaxy S II T989 Front Camera Replacement, Front Camera: step 9, image 2 of 2
    • To remove the front camera we need to first remove the screw indicated by the red circle and the cover plate. The screw size is 1/16 of an inch (1.6 mm)
    • After the screw has been removed, the cover plate can be removed.
  10. Samsung Galaxy S II T989 Front Camera Replacement: step 10, image 1 of 2 Samsung Galaxy S II T989 Front Camera Replacement: step 10, image 2 of 2
    Buy
    • Use the tweezers to remove the plastic bar which holds the camera in place.
  11. Samsung Galaxy S II T989 Front Camera Replacement: step 11, image 1 of 3 Samsung Galaxy S II T989 Front Camera Replacement: step 11, image 2 of 3 Samsung Galaxy S II T989 Front Camera Replacement: step 11, image 3 of 3
    • The camera is now exposed.
    • Carefully lift the camera out of the phone with the tweezers.
3 other people completed this guide.
Joshua King
1,378 Reputation
9 Guides authored
Clemson, Team 1-5, Benson Spring 2014 Member of Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,698
