Samsung Galaxy S Vibrant Battery Replacement
  1. Samsung Galaxy S Vibrant Battery Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy S Vibrant Battery Replacement, Battery: step 1, image 3 of 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Battery Replacement: step 2, image 1 of 2 Samsung Galaxy S Vibrant Battery Replacement: step 2, image 2 of 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
Taylor Catlin
79 Reputation
6 Guides authored
Cal Poly, Team 18-37, Regan Winter 2013 Member of Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 30
All Time: 1,691
