Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement
  1. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Battery: step 1, image 3 of 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 2, image 1 of 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 2, image 2 of 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Midframe: step 3, image 1 of 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 4, image 1 of 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 5, image 1 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 5, image 2 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 5, image 3 of 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 6, image 1 of 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 6, image 2 of 2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: step 7, image 1 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: step 7, image 2 of 3 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Unhooking Antenna Cable: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
    • Do the lower end first, and then the upper.
    • Pull the antenna cable out.
  8. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: step 8, image 1 of 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement, Headphone Jack/Ear Speaker: step 8, image 2 of 2
    • Locate the three snap on ribbon cable connectors on the motherboard.
    • Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
  9. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 9, image 1 of 1
    • With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
    • Take care when moving the motherboard not to allow any of the ribbon cables to be pulled on.
    • The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
  10. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 10, image 1 of 1
    • Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
    • Take care to not damage the button itself or its connecting ribbon cable when detaching the button.
    • The glue which holds the button in place will remain tacky allowing the button to be replaced without the need for additional glue.
  11. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 11, image 1 of 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 11, image 2 of 2
    • With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
    • Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
    • The Headphone Jack is held in place with adhesive that will remain tacky after being removed, allowing it to be replace without the need for additional glue.
  12. Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 12, image 1 of 2 Samsung Galaxy S Vibrant Headphone Jack/Ear Speaker Replacement: step 12, image 2 of 2
    • Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
    • The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
    • With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
Taylor Catlin
79 Reputation
6 Guides authored
Cal Poly, Team 18-37, Regan Winter 2013 Member of Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Members
8 Guides authored
One Comment
Nice Idea Good for beginners. :)
Spy Mike - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 17
All Time: 3,093
