Samsung Galaxy S10 Back Cover Replacement
  1. Samsung Galaxy S10 Back Cover Replacement, Heat the back cover: step 1, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement, Heat the back cover: step 1, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement, Heat the back cover: step 1, image 3 of 3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
  2. Samsung Galaxy S10 Back Cover Replacement, Create an opening gap: step 2, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement, Create an opening gap: step 2, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement, Create an opening gap: step 2, image 3 of 3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
  3. Samsung Galaxy S10 Back Cover Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement, Insert an opening pick: step 3, image 3 of 3
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances and strong adhesive, multiple attempts may be necessary to create a gap for the opening pick.
    • If you are having trouble creating a gap, the adhesive isn't weakened enough. Make sure you have heated the edge until just barely too hot to touch try this step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
  4. Samsung Galaxy S10 Back Cover Replacement, Slice through the adhesive: step 4, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement, Slice through the adhesive: step 4, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement, Slice through the adhesive: step 4, image 3 of 3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  5. Samsung Galaxy S10 Back Cover Replacement: step 5, image 1 of 2 Samsung Galaxy S10 Back Cover Replacement: step 5, image 2 of 2
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  6. Samsung Galaxy S10 Back Cover Replacement: step 6, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement: step 6, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement: step 6, image 3 of 3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  7. Samsung Galaxy S10 Back Cover Replacement: step 7, image 1 of 3 Samsung Galaxy S10 Back Cover Replacement: step 7, image 2 of 3 Samsung Galaxy S10 Back Cover Replacement: step 7, image 3 of 3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
After you've completed the repair, follow this guide to test your repair.
23 other people completed this guide.
Arthur Shi
258,874 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
11 Comments
Will this ruin the waterproofing?
Håkon - Reply
Hi Håkon,
Yes, opening the S10 will compromise its water resistance.
Arthur Shi -
So to fix this issue and retain water proofing I should send it back to Samsung for them to repair/replace?
Håkon -
That is an option. You can also try their authorized repair centers, or independent repair centers. Note that even if they say they will restore water resistance with the repair, they will most likely not guarantee it. That is because the IP68 water resistance rating test is verified on brand new phones. As the phone ages, it loses water resistance because the seals and adhesives break down.
Arthur Shi -
What about using a epoxy resin? it is only a small crack on the back, nothing major. I'll check out a service center as well.
Sorry for all the question!
Håkon -
Past 24 Hours: 18
Past 7 Days: 112
Past 30 Days: 677
All Time: 77,186
