Introduction
Follow this guide to remove and replace a broken screen for your Samsung Galaxy S10e. This involves removing the back cover in order to disconnect the screen from the motherboard.
This guide destructively removes the screen panel while retaining the original frame. The screen consists of the top glass and the display panel. Even though the procedure will remove the top glass separately from the panel, you will not be able to reuse the screen.
Turn your phone off completely before you begin this repair.
Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
Use the flat end of a spudger to pry the battery connector straight up from its socket and disconnect it.
Use a Phillips driver to remove the seven 3.9 mm screws securing the loudspeaker.
Use the flat end of a spudger to pry up and disconnect the screen connector from its motherboard socket.
Flip the phone over so that the display is facing up.
Apply a heated iOpener to the right edge of the screen for two minutes.
Display seam—this seam sits above the thin plastic bezel. You need to pry along this seam to separate the display.
Frame seam—this seam sits below the thin plastic bezel. Do not pry along this seam or you will damage the plastic bezel.
Apply a heated iOpener to the OLED panel for a minute to soften up the panel adhesive.
After you've completed the repair, follow this guide to test your repair.
16 other people completed this guide.
