Introduction
Follow this guide to remove the glass back cover for replacement or to access the Samsung Galaxy S20’s internals.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
Tool used on this step:Tweezers$4.99
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
17 other people completed this guide.
3 Comments
Cool, great advice
Did not work at all for me. Tried the iOpener many times and a hair dryer plus the suction cup but no luck. In the end I used an Exacto knife to just begin to gently break the glass cover in one spot, inserting no further than the glue edge and then twisting, and cracked the whole thing which thereafter I just peeled off in one minute and cut the adhesive as I went, since it was going to be thrown away when replaced with the new one. Perfect and quick.
Was easy for me because the backside was coming off anyways. (used desinfectant too often on my hands + phone).
I think the hyperlinks at the end are not right: they both lead to the same guide using pre cut tape.
