Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement
  1. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Before you begin: step 1, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Before you begin: step 1, image 2 of 2
    • Before you begin, let your battery drain below 25%—a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your phone and unplug any cables.
  2. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Heat the bottom edge: step 2, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • You can also use a hair dryer—but be careful, as extreme heat will warp the back cover.
  3. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction cup to the center of the back cover's bottom edge, as close to the edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and frame.
    • This will require significant force. If you're having trouble, apply more heat and try again.
    • Insert an opening pick in the gap.
  4. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 4, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 4, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 4, image 3 of 3
    • Slide the opening pick along the bottom edge to slice the adhesive securing the back cover.
    • Leave the opening pick inserted in the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Heat the right edge: step 5, image 1 of 1
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  6. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the right adhesive: step 6, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the right adhesive: step 6, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the right adhesive: step 6, image 3 of 3
    • Slide the opening pick around the bottom right corner and all the way up the right edge to slice the adhesive.
    • Leave the opening pick inserted in the top right corner.
  7. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Heat the top edge: step 7, image 1 of 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  8. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the top adhesive: step 8, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the top adhesive: step 8, image 2 of 2
    • Slide the opening pick around the top right corner and along the top edge to slice the adhesive.
    • Leave the pick inserted in the top left corner.
  9. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Heat the left edge: step 9, image 1 of 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the left adhesive: step 10, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the left adhesive: step 10, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Slice the left adhesive: step 10, image 3 of 3
    • Slide the opening pick around the top left corner and all the way down the left edge to slice the remaining adhesive.
  11. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the back cover: step 11, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the back cover: step 11, image 2 of 2
    • Remove the back cover.
    • If the back cover is still stuck to the frame, slide an opening pick around the perimeter to separate any remaining adhesive.
  12. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Reassembly information: step 12, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Reassembly information: step 12, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Reassembly information: step 12, image 3 of 3
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
    • If you're reinstalling your old back cover:
    • Use tweezers or your fingers to peel off the old adhesive from the back cover and frame.
    • Use highly-concentrated isopropyl alcohol (over 90%) and a microfiber cloth to remove any remaining adhesive residue.
    • Follow this guide to apply new custom-cut adhesive.
    • If you're installing a new back cover, peel off the liners and press firmly around the perimeter to secure the back cover to the frame.
  13. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unfasten the wireless charging assembly: step 13, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unfasten the wireless charging assembly: step 13, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unfasten the wireless charging assembly: step 13, image 3 of 3
    • The wireless charging assembly includes the motherboard cover, wireless charging coil, and loudspeaker. They're held together with graphite tape and should be removed as one piece.
    • Use a Phillips screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Nine 4 mm-long screws securing the motherboard cover
    • Seven 4.5 mm-long screws securing the loudspeaker
  14. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the motherboard cover: step 14, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the motherboard cover: step 14, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the motherboard cover: step 14, image 3 of 3
    • Insert a pick under the bottom right edge of the motherboard cover.
    • Twist the pick to release the clips securing the cover.
    • Insert and twist the opening pick on the bottom left edge of the cover to release the remaining clips.
    • During reassembly, press down firmly around the perimeter of the motherboard cover to engage the clips.
  15. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Reposition the motherboard cover: step 15, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Reposition the motherboard cover: step 15, image 2 of 2
  16. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Disconnect the battery: step 16, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Disconnect the battery: step 16, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Disconnect the battery: step 16, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the battery and wireless charging press connectors from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  17. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 17, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 17, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 17, image 3 of 3
    • Insert the point of a spudger between the bottom left corner of the loudspeaker and the frame.
    • Pry up to release the clips securing the left edge of the loudspeaker.
    • Pry up the bottom right corner of the loudspeaker to release the remaining clips.
    • During reassembly, press down firmly around the perimeter of the loudspeaker to engage the clips.
  18. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the wireless charging assembly: step 18, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the wireless charging assembly: step 18, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the wireless charging assembly: step 18, image 3 of 3
    • Remove the wireless charging assembly.
  19. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Disconnect the charging board cables: step 19, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Disconnect the charging board cables: step 19, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the display cable press connector from the charging board.
  20. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 20, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 20, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 20, image 3 of 3
    • Use a spudger to disconnect the fingerprint sensor and interconnect cable press connectors.
  21. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 21, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 21, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 21, image 3 of 3
    • Slide one arm of your angled tweezers under the head of the white antenna cable.
    • Gently lift straight up to disconnect the cable.
    • Use the same process to disconnect the red antenna cable.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  22. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 22, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement: step 22, image 2 of 2
    • Gently lift the red and white antenna cables out of their clips on the charging board.
    • During reassembly, make sure the antenna cables are in their channels on the right edge of the phone before pressing them into their clips.
  23. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unfasten the charging board: step 23, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Unfasten the charging board: step 23, image 2 of 2
    • Use a Phillips screwdriver to remove the 3.5 mm-long screw securing the charging board.
  24. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Pry up the charging board: step 24, image 1 of 2 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Pry up the charging board: step 24, image 2 of 2
    • Use a spudger to pry up the left side of the charging board until you can grip it with your fingers.
  25. Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the charging board: step 25, image 1 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the charging board: step 25, image 2 of 3 Samsung Galaxy S20 FE 5G USB-C Port and Charging Board Replacement, Remove the charging board: step 25, image 3 of 3
    • Grip the charging board by its top edge and pull it out of its recess at a 45-degree angle.
    • During reassembly:
    • Make sure the five cables that connect to the motherboard are out of the way so they don't get stuck under the board.
    • Insert the charging board at a downward angle and guide the USB-C port into its recess.
    • Push the charging board down firmly until it's snug in its recess.
Compare your new replacement part to the original part—you may need to transfer remaining from the new part before you install it.
Spencer Day
95,619 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
119 Members
19,523 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 71
Past 30 Days: 264
All Time: 852
