Introduction
Follow this guide to remove the loudspeaker for the Samsung Galaxy S20 Plus. The loudspeaker is integrated into the lower midframe, so these parts will need to be replaced together.
You'll need replacement adhesive in order to complete this repair.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
Remove the loudspeaker and lower midframe.
After you've completed the repair, follow this guide to test your repair.
2 other people completed this guide.
