Introduction
This guide shows how to remove and replace the battery for the Samsung Galaxy S20 Ultra.
The battery is held in place with strong adhesive. High concentration (over 90%) isopropyl alcohol is necessary to loosen and release this adhesive.
If your battery is swollen, take appropriate precautions and do not heat your phone.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You'll need replacement adhesive in order to complete this repair.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave your opening pick in the seam to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to unclip and remove the motherboard bracket.
Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the loudspeaker and lower midframe.
Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
Remove the loudspeaker and lower midframe.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
Gently peel up and remove the main and auxiliary flex cables.
Pry up and disconnect the left 5G antenna cable from the motherboard.
Pry up and disconnect the main display flex cable from the motherboard.
Gently peel up and bend the display and left 5G antenna flex cables out of the way of the motherboard and battery.
Apply a few drops of high concentration (over 90%) isopropyl alcohol to the gaps in between the frame and the edges of the battery.
Tilt the device gently as you apply the alcohol help it penetrate the adhesive underneath the battery.
After you apply the alcohol, continue tilting the phone gently in all directions for three to five minutes to help the alcohol penetrate further and evaporate.
Apply a suction handle to the center of the battery.
Brace the top and bottom of the device against your work surface with one hand and firmly pull up on the suction handle with the other.
Continue lifting until the battery separates from the phone.
Remove the battery.
Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
5 other people completed this guide.
6 Comments
The new battery stays at zero percent when it’s charging
But it charges or not?
Where did you buy this battery, avoid ebay only buy from trusted sources with warranty like ifixit
I bought a galaxy s7 battery on eBay claiming to be original quality it swelled up badly in 2 days
I completed this repair yesterday and for awhile everything was working. Now it looks like there’s residual isopropyl alcohol in the camera assembly and the screen is no longer working. For awhile touch input stopped but the display remained and now the display has stopped as well. I’m worried I damaged something by using too much alcohol when getting the battery out, or maybe on the display cable when reattaching it during reassembly. How do I go about finding out what the issue is and hopefully fix it?
This exact issue happened to me as well, word for word how you put it. Took my phone to a repair store and they said the motherboard was damaged and there was nothing they could do. The wording this guide had before was extremely dangerous and probably killed a lot of people's phones.
