Introduction
Use this guide to replace the back cover on your Samsung Galaxy S22+.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Prepare an iOpener and apply it to the bottom edge of the back cover for three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Remove the suction handle.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick inserted near the bottom left corner to prevent the adhesive from resealing.
Apply the heated iOpener to the left edge of the phone for 3 minutes to soften the adhesive.
Reheat your iOpener for 30 seconds if necessary.
Insert a second opening pick into the gap created near the bottom left corner.
Slide the opening pick along the left edge to slice the adhesive.
Leave the opening pick inserted near the top left corner to prevent the adhesive from resealing.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
