Samsung Galaxy S23 Back Cover Replacement
  1. Samsung Galaxy S23 Back Cover Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S23 Back Cover Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Samsung Galaxy S23 Back Cover Replacement, Heat the right edge: step 2, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S23 Back Cover Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S23 Back Cover Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the right adhesive: step 4, image 3 of 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S23 Back Cover Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 6, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 6, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 6, image 3 of 3
    • Insert a second opening pick at the bottom right corner.
    • Rotate it around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S23 Back Cover Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S23 Back Cover Replacement, Separate the bottom adhesive: step 7, image 2 of 2
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S23 Back Cover Replacement, Heat the left edge: step 8, image 1 of 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 9, image 2 of 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S23 Back Cover Replacement, Separate the left adhesive: step 10, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the left adhesive: step 10, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the left adhesive: step 10, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Slide your pick toward the top left corner to separate the adhesive.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  11. Samsung Galaxy S23 Back Cover Replacement, Heat the top edge: step 11, image 1 of 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 12, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 12, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the corner adhesive: step 12, image 3 of 3
    • Insert a fourth opening pick at the top left corner.
    • Rotate it around the top left corner to separate the adhesive.
  13. Samsung Galaxy S23 Back Cover Replacement, Separate the top adhesive: step 13, image 1 of 2 Samsung Galaxy S23 Back Cover Replacement, Separate the top adhesive: step 13, image 2 of 2
    • Slide your opening pick to the top right corner to separate the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Samsung Galaxy S23 Back Cover Replacement, Separate the flash adhesive: step 14, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the flash adhesive: step 14, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Separate the flash adhesive: step 14, image 3 of 3
    • There's a remaining patch of adhesive directly under the flash.
    • Line up the tip of an opening pick with the flash cutout.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • You should see the opening pick through the flash cutout.
    • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
    • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
  15. Samsung Galaxy S23 Back Cover Replacement, Remove the back cover: step 15, image 1 of 3 Samsung Galaxy S23 Back Cover Replacement, Remove the back cover: step 15, image 2 of 3 Samsung Galaxy S23 Back Cover Replacement, Remove the back cover: step 15, image 3 of 3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S23 Answers Community for troubleshooting help.
3 other people completed this guide.
Alex Diaz-Kokaisl
162,690 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,475 Guides authored
One Comment
Why no illustrations on how to get it back together?
Reformed Stoic - Reply
Past 24 Hours: 10
Past 7 Days: 73
Past 30 Days: 256
All Time: 972
