Samsung Galaxy S23 Screen Replacement
  1. Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Samsung Galaxy S23 Screen Replacement, Heat the right edge: step 2, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: step 4, image 3 of 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S23 Screen Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 6, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 6, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 6, image 3 of 3
    • Insert a second opening pick at the bottom right corner.
    • Rotate it around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: step 7, image 2 of 2
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S23 Screen Replacement, Heat the left edge: step 8, image 1 of 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 9, image 2 of 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: step 10, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: step 10, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: step 10, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • Slide your pick toward the top left corner to separate the adhesive.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  11. Samsung Galaxy S23 Screen Replacement, Heat the top edge: step 11, image 1 of 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 12, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 12, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: step 12, image 3 of 3
    • Insert a fourth opening pick at the top left corner.
    • Rotate it around the top left corner to separate the adhesive.
  13. Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: step 13, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: step 13, image 2 of 2
    • Slide your opening pick to the top right corner to separate the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: step 14, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: step 14, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: step 14, image 3 of 3
    • There's a remaining patch of adhesive directly under the flash.
    • Line up the tip of an opening pick with the flash cutout.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • You should see the opening pick through the flash cutout.
    • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
    • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
  15. Samsung Galaxy S23 Screen Replacement, Remove the back cover: step 15, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Remove the back cover: step 15, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Remove the back cover: step 15, image 3 of 3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  17. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 3 of 3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  18. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 3 of 3
    • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
    • Pry up to unclip the loudspeaker from the frame.
  19. Samsung Galaxy S23 Screen Replacement: step 19, image 1 of 3 Samsung Galaxy S23 Screen Replacement: step 19, image 2 of 3 Samsung Galaxy S23 Screen Replacement: step 19, image 3 of 3
    • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  20. Samsung Galaxy S23 Screen Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Disconnect the battery: step 20, image 2 of 2
    • Use the point of your spudger to pry up and disconnect the battery press connector.
  21. Samsung Galaxy S23 Screen Replacement, Disconnect the display: step 21, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Disconnect the display: step 21, image 2 of 2
    • Use the flat end of your spudger to pry up and disconnect the display cable press connector from the back of the screen.
  22. Samsung Galaxy S23 Screen Replacement, Put the back cover on: step 22, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Put the back cover on: step 22, image 2 of 2
    • Put the back cover on the frame to protect the battery and your phone's internals from damage.
    • Don't apply new adhesive at this step, as you'll need to remove the back cover again to finish reassembly. The old adhesive will be enough to keep the back cover in place while you replace the screen.
    • Flip your phone over so the screen is facing up.
  23. Samsung Galaxy S23 Screen Replacement, Tool and safety information: step 23, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Tool and safety information: step 23, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Tool and safety information: step 23, image 3 of 3
    Tool used on this step:
    iFlex Opening Tool
    $11.99
    Buy
    • The gap between the front glass and frame is very small. You'll need a thin, rigid tool such as an iFlex to create an initial gap.
    • Take the following safety precautions while removing the front glass during the next steps:
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp.
    • The front glass may shatter and spread shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
  24. Samsung Galaxy S23 Screen Replacement, Heat the screen: step 24, image 1 of 1
    • Use a hair dryer or heat gun to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  25. Samsung Galaxy S23 Screen Replacement, Insert an iFlex: step 25, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: step 25, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: step 25, image 3 of 3
    • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
    • Insert the iFlex at a downward angle in the earpiece speaker gap between the top edge of the front glass and frame.
    • Lift the suction handle with strong, steady force and lower the iFlex so it slides under the front glass. A large portion of the front glass may separate—that's fine.
    • The front glass will peel away from the display panel, causing it to appear discolored. This is normal. You will remove the display panel in a later step.
    • The iFlex only needs to be inserted just enough to separate the front glass and create an initial gap. If inserted too far, it may damage the front-facing camera.
  26. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 26, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 26, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: step 26, image 3 of 3
    • Rotate the iFlex around one of the top corners of the front glass to separate enough adhesive to insert an opening pick.
  27. Samsung Galaxy S23 Screen Replacement, Remove the front glass: step 27, image 1 of 3 Samsung Galaxy S23 Screen Replacement, Remove the front glass: step 27, image 2 of 3 Samsung Galaxy S23 Screen Replacement, Remove the front glass: step 27, image 3 of 3
    • Slide the opening pick around the perimeter of the front glass to separate the adhesive securing it to the frame.
  28. Samsung Galaxy S23 Screen Replacement: step 28, image 1 of 2 Samsung Galaxy S23 Screen Replacement: step 28, image 2 of 2
    • Lift the front glass off the frame and remove it.
  29. Samsung Galaxy S23 Screen Replacement, Remove the screen panel: step 29, image 1 of 2 Samsung Galaxy S23 Screen Replacement, Remove the screen panel: step 29, image 2 of 2
    • Insert an opening pick under the screen panel.
    • If you're having trouble separating the adhesive, use a hair dryer or heat gun to heat the screen panel until it's warm to the touch.
  30. Samsung Galaxy S23 Screen Replacement: step 30, image 1 of 3 Samsung Galaxy S23 Screen Replacement: step 30, image 2 of 3 Samsung Galaxy S23 Screen Replacement: step 30, image 3 of 3
    • Slide the opening pick around the perimeter of the screen panel to separate the adhesive securing it to the frame.
  31. Samsung Galaxy S23 Screen Replacement: step 31, image 1 of 3 Samsung Galaxy S23 Screen Replacement: step 31, image 2 of 3 Samsung Galaxy S23 Screen Replacement: step 31, image 3 of 3
    • Grip a corner of the screen panel and slowly peel it off the frame to separate the remaining adhesive.
    • Remove the screen panel.
    • You're now ready to replace your screen.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S23 Answers Community for troubleshooting help.
Alex Diaz-Kokaisl
216,162 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,888 Guides authored
0 Guide Comments
Past 24 Hours: 44
Past 7 Days: 304
Past 30 Days: 1,159
All Time: 12,799
