Samsung Galaxy S4 Active I537 Charging port Replacement
  1. Samsung Galaxy S4 Active I537 Charging port Replacement, Rear Cover: step 1, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement, Rear Cover: step 1, image 2 of 2
    • Remove back cover
    • Remove battery
  2. Samsung Galaxy S4 Active I537 Charging port Replacement, remove screws: step 2, image 1 of 1
    • remove battery before taking off screws
    • remove the 8 screws in the back using a small Phillips screw driver
  3. Samsung Galaxy S4 Active I537 Charging port Replacement, Covers: step 3, image 1 of 1
    • using a prying tool or something remove the 4 covers that are blocking the last 4 screws
    • you might have to put a bit of pressure to get them off
  4. Samsung Galaxy S4 Active I537 Charging port Replacement, More screws: step 4, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement, More screws: step 4, image 2 of 2
    • Remove the 4 screws
    • with a prying tool or fingers go around the edges to remove the plastic back part of the phone
    • be carefull not to break it by using too much force
  5. Samsung Galaxy S4 Active I537 Charging port Replacement, Screws: step 5, image 1 of 1
    • Remove these 2 screws then take off the white plastic part
  6. Samsung Galaxy S4 Active I537 Charging port Replacement, Antenna cable: step 6, image 1 of 1
    • use prying tool or finger to unplug antenna cable
    • be extra careful unplugging this
  7. Samsung Galaxy S4 Active I537 Charging port Replacement: step 7, image 1 of 1
    • use prying tool or fingers to unplug this connection
    • again be careful
  8. Samsung Galaxy S4 Active I537 Charging port Replacement: step 8, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement: step 8, image 2 of 2
    • you can now use the prying tool or fingers to remove the charging port and replace it with the new one
    • follow steps in reverse to resemble
    • carefully
16 other people completed this guide.
ted582 ted583
529 Reputation
1 Guide authored
3 Comments
Good tear down procedure.
tcjd1976 - Reply
I replaced Charging Port on my Samsung SGH-i537 about a week ago (Before I found this “Tear-Down Procedure”.)! You did a nice job putting this information together!
It’s relatively simple, although sometimes I feel like “the more information the better”!
I DO HAVE A QUESTION: After I removed the screws, and separated the two halves of my phone, I turned the front half face-up, and a small, flat, black clip I didn’t notice, fell from SOMEWHERE! Despite my looking for many various possibilities as to where this clip goes back into my phone, I didn't find a place that it would fit properly. I’m sure it’s location is staring me in the face, but I’m still not finding it!
After a whole lot more looking, one square centimeter at a time, I reluctantly decided to put my phone back together without this “clip”.
The phone works great! But I know this “clip” was in it for a reason, so I’m having a hard time calling this repair a complete success!
Does anybody know exactly where this “clip” goes?
Thanks!
Roger.
Roger C. Smith - Reply
I think it holds the midframe in. No worries, my midframe stays in with 3 screws.
[deleted] -
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 7,889
