Samsung Galaxy S4 Active Midframe Replacement
  1. Samsung Galaxy S4 Active Midframe Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Active Midframe Replacement, Rear Case: step 1, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Midframe Replacement, MicroSD Card: step 2, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Midframe Replacement, Battery: step 3, image 1 of 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Midframe Replacement, SIM Card: step 4, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Midframe Replacement, Midframe: step 5, image 1 of 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Midframe Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
9 other people completed this guide.
Geoff Wacker
91,058 Reputation
89 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,445
