Samsung Galaxy S4 Mini Speaker Replacement
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: step 1, image 1 of 1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: step 2, image 1 of 1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: step 3, image 1 of 1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: step 4, image 1 of 2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: step 4, image 2 of 2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: step 5, image 1 of 1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: step 6, image 1 of 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: step 6, image 2 of 3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: step 6, image 3 of 3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: step 7, image 1 of 2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: step 7, image 2 of 2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: step 8, image 1 of 1
    • Insert the new loud speaker
31 other people completed this guide.
Luis Ojeda
989 Reputation
1 Guide authored
USF Tampa, Team 9-2, Blackwell Fall 2014 Member of USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Members
11 Guides authored
3 Comments
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Reply
loud & clear Thanks
Maarten Brenninkmeijer - Reply
perfect. thankyou
rick bailey - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 13,793
