Introduction
Use this guide to replace the motherboard in your Samsung Galaxy S4.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
159 other people completed this guide.
30 Comments
I have a M919 with dead motherboard. Can i swap with an i9505motherboard insted? will all the components work on this new motherboard?
Hi I have a question. I have Galaxy S4 but The screen just broke and my sister give her galaxy s4 can i just change the motherboard to my phone or need to change the other parts too? Please help my i dont want to change all the parts if i dont need to!?
Mboard only.
i need S4 mother board too broher pls give me if you have extra i will pay
