Introduction
Use this guide to replace the Micro-USB port daughterboard.
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
Carefully wedge the tip of a spudger underneath the antenna cable connector.
Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
Use the flat end of a spudger to carefully peel the soft button cables up off the interior midframe.
176 other people completed this guide.
40 Comments
Since replacing the part I cannot register on the network, Wifi works, cellular says full signal but selected network unavailable. Sim works in another phone and another sim doesn't work in this phone.
Adam -
Make sure you reatach the tiny connector that was taken off in step 28. That is crucial to reception and can easily fail to click into place. It seems very likely that that is the problem.
Adam, did you make sure you replaced with the exact same model?
my apple -
