Samsung Galaxy S5 Mini Daughterboard Replacement
Video Overview
  1. Samsung Galaxy S5 Mini Daughterboard Replacement, Daughterboard: step 1, image 1 of 1
    • Remove battery cover.
  2. Samsung Galaxy S5 Mini Daughterboard Replacement: step 2, image 1 of 1
    • Remove battery. If you have the SIM card and SD card in, remove them by the way.
  3. Samsung Galaxy S5 Mini Daughterboard Replacement: step 3, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 3, image 2 of 2
    • Open this small cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 1 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 2 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 3 of 3
    • Heat up the screen, cut the sticker and release the LCD screen connector carefully.
  5. Samsung Galaxy S5 Mini Daughterboard Replacement: step 5, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 5, image 2 of 2
    • Remove LCD screen.
  6. Samsung Galaxy S5 Mini Daughterboard Replacement: step 6, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 6, image 2 of 2
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini Daughterboard Replacement: step 7, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 7, image 2 of 2
    • Remove mid-plate.
  8. Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 1 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 2 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 3 of 3
    • Remove screw, release USB board flex connector and antenna cable connectors.
  9. Samsung Galaxy S5 Mini Daughterboard Replacement: step 9, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 9, image 2 of 2
    • Remove the daughterboard and clean the signal cables from assembly. And you can replace the new USB charging board for Samsung Galaxy S5 Mini.
7 other people completed this guide.
Sophia
43,822 Reputation
62 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 5,874
