Samsung Galaxy S5 Sport Screen Replacement
  1. Samsung Galaxy S5 Sport Screen Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy S5 Sport Screen Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy S5 Sport Screen Replacement, Battery: step 1, image 3 of 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Screen Replacement: step 2, image 1 of 3 Samsung Galaxy S5 Sport Screen Replacement: step 2, image 2 of 3 Samsung Galaxy S5 Sport Screen Replacement: step 2, image 3 of 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Screen Replacement, Screen: step 3, image 1 of 3 Samsung Galaxy S5 Sport Screen Replacement, Screen: step 3, image 2 of 3 Samsung Galaxy S5 Sport Screen Replacement, Screen: step 3, image 3 of 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Screen Replacement: step 4, image 1 of 2 Samsung Galaxy S5 Sport Screen Replacement: step 4, image 2 of 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
4 other people completed this guide.
Caroline Janiszewski
528 Reputation
4 Guides authored
USF Tampa, Team 1-6, Leahy Spring 2016 Member of USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 3,926
