Introduction
So one day after only owning my new Galaxy S6 Edge for a month I noticed I was getting fuzzy pictures. I turned the phone and saw that the glass over my camera was shattered.
Be careful when removing the shattered glass. You want to make sure the pieces don't fall inside and get trapped next to the camera. You also want to make sure that the lens on the camera itself is not in need of replacement. To do that you would need to remove the back cover and fortunately, I did not have to do this to complete my repair.
You'll want to make sure when you purchase your replacement glass that you get a new piece of glue tape to secure the glass. No matter how careful you are the old glue will not be sticky enough or lay flat enough for your new glass to stay securely flush with the camera dome.
I chose to keep the center section in when applying the glue tape. This was to prevent the tape from accidentally getting stuck to the camera. I could have instead removed the circle before placing the tape down and this would have prevented me from having to awkwardly pry it out afterward. Pick your own battle...
Next carefully remove the protective plastic from BOTH sides of your replacement glass. It's easy to forget the backside. I almost stuck the plastic to my phone. Doing so would have let my new glass come right off.
After peeling the plastic off, gently grip the glass with the tweezers or small suction gripping tool and place inside the camera dome. Firmly press into place making sure the edge is flush if not slightly lower than the edge of the dome.
I wiped my glass clean and let the warm iOpener sit on top to warm the glue. I have no idea if this resulted in a firmer grip after cooling, but it seemed to have made the glass more level.
So comes the end of my first phone repair and thus this tutorial. I hope I made someone a little less trepidatious about doing this repair themselves!
24 other people completed this guide.
22 Comments
I think they have the exact same camera. See:
http://www.gsmarena.com/compare.php3?idP...
Im going to buy it and try it myself. I'm sure if you wanted to replace the entire camera, you'd have to get one made for that phone, but this is just the lens, so I'm sure they're the same size and dimensions.
Was your camera blurry when it was damaged as mines smashed and camera works but won't focus.. any help anyone please?
Did you ever get a reply to this? I am having the same issue
