Samsung Galaxy S7 Active Screen Replacement
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: step 1, image 1 of 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: step 2, image 1 of 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: step 3, image 1 of 2 Samsung Galaxy S7 Active Screen Replacement: step 3, image 2 of 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: step 4, image 1 of 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 1 of 3 Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 2 of 3 Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: step 6, image 1 of 3 Samsung Galaxy S7 Active Screen Replacement: step 6, image 2 of 3 Samsung Galaxy S7 Active Screen Replacement: step 6, image 3 of 3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
3 other people completed this guide.
Erick Vazquez
180 Reputation
1 Guide authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
15 Guides authored
3 Comments
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Reply
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Reply
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 9,103
