Samsung Galaxy S7 Display Adhesive Replacement
  1. Samsung Galaxy S7 Display Adhesive Replacement, Display Adhesive: step 1, image 1 of 2 Samsung Galaxy S7 Display Adhesive Replacement, Display Adhesive: step 1, image 2 of 2
    • Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
    • If glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • Peel off the clear plastic backing from the pre-cut adhesive strip, exposing one side of adhesive.
  2. Samsung Galaxy S7 Display Adhesive Replacement: step 2, image 1 of 3 Samsung Galaxy S7 Display Adhesive Replacement: step 2, image 2 of 3 Samsung Galaxy S7 Display Adhesive Replacement: step 2, image 3 of 3
    • Carefully line up an edge of the adhesive with the corresponding edge of the phone frame. Make sure the adhesive is properly oriented.
    • Set the adhesive down lightly on the frame.
    • Make sure that the adhesive cutouts match the phone, and that the camera and sensors are not covered by adhesive.
    • If it is not properly aligned, carefully peel the adhesive back up.
  3. Samsung Galaxy S7 Display Adhesive Replacement: step 3, image 1 of 3 Samsung Galaxy S7 Display Adhesive Replacement: step 3, image 2 of 3 Samsung Galaxy S7 Display Adhesive Replacement: step 3, image 3 of 3
    • Once the adhesive is aligned on the frame, run the flat end of a spudger around the perimeter of the adhesive to press it into place. You can also use your fingers.
  4. Samsung Galaxy S7 Display Adhesive Replacement: step 4, image 1 of 1
    • Continue reassembling your device until you are ready to attach the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Peel and remove the green plastic liner from the adhesive strip to expose the screen-facing adhesive.
    • Align and set the phone screen on top of the adhesive.
    • Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Follow this link to return to the Galaxy S7 screen replacement guide.
13 other people completed this guide.
Arthur Shi
258,874 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,060 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 10,121
