Samsung Galaxy S8 Active Loudspeaker Assembly Replacement
  1. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, SIM Tray/Card: step 1, image 1 of 2 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, SIM Tray/Card: step 1, image 2 of 2
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, NFC Antenna and Charging Coil Assembly: step 2, image 1 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, NFC Antenna and Charging Coil Assembly: step 2, image 2 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, NFC Antenna and Charging Coil Assembly: step 2, image 3 of 3
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
  3. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 3, image 1 of 1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 4, image 1 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 4, image 2 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 4, image 3 of 3
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 5, image 1 of 1
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 6, image 1 of 2 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 6, image 2 of 2
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 7, image 1 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 7, image 2 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 7, image 3 of 3
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
  8. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 8, image 1 of 2 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement: step 8, image 2 of 2
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, Loudspeaker Assembly: step 9, image 1 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, Loudspeaker Assembly: step 9, image 2 of 3 Samsung Galaxy S8 Active Loudspeaker Assembly Replacement, Loudspeaker Assembly: step 9, image 3 of 3
    • Remove the loudspeaker assembly using the flat end of a spudger.
2 other people completed this guide.
Ariel Sampson
709 Reputation
3 Guides authored
Cal Poly, Team S2-G1, White Winter 2019 Member of Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 924
