Samsung Galaxy S8 Plus Motherboard Replacement
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
6 other people completed this guide.
Alex Sander
38,363 Reputation
202 Guides authored
3 Comments
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - Reply
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - Reply
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - Reply
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 108
All Time: 11,113
