Samsung Galaxy SIII Mini Display Assembly Replacement
Video Overview
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: step 2, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 2, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 2, image 3 of 3
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 3, image 3 of 3
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: step 4, image 1 of 1
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: step 5, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 5, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 5, image 3 of 3
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: step 6, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 6, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 6, image 3 of 3
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: step 7, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 7, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 7, image 3 of 3
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: step 8, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 8, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 8, image 3 of 3
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 9, image 3 of 3
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: step 10, image 1 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 10, image 2 of 3 Samsung Galaxy SIII Mini Display Assembly Replacement: step 10, image 3 of 3
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: step 11, image 1 of 1
    • That's all.
    • Did you do it successfully?
18 other people completed this guide.
ZFix
195,994 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
2 Guide Comments
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Reply
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 31
All Time: 17,860
