Samsung Galaxy SIII Mini VE Front Camera Replacement
  1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: step 1, image 1 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: step 1, image 2 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: step 1, image 3 of 3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: step 2, image 1 of 2 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: step 2, image 2 of 2
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Screws: step 3, image 1 of 1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy SIII Mini VE Front Camera Replacement: step 4, image 1 of 2 Samsung Galaxy SIII Mini VE Front Camera Replacement: step 4, image 2 of 2
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: step 5, image 1 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: step 5, image 2 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: step 6, image 1 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: step 6, image 2 of 3 Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: step 6, image 3 of 3
    Buy
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
2 other people completed this guide.
Megan
1,186 Reputation
6 Guides authored
Michigan Tech, Team 1-8, Lauer Fall 2014 Member of Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,110
