Samsung Galaxy Sol Speaker Replacement
  1. Samsung Galaxy Sol Speaker Replacement, Battery: step 1, image 1 of 1
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: step 2, image 1 of 1
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: step 4, image 1 of 1
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 412
