Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement
Amy Tsai
Amy Tsai and 3 other contributors
Last updated on May 27, 2024
10 - 15 minutes
Easy
Incorrect Tools
Introduction
Go to step 1
If the audio does not play, even after you restart the device, then you may need to replace the headphone jack.
In this guide, you will learn how to replace the headphone jack.
Caution: Some images display the steps using a metal spudger. Use the heavy-duty spudger instead to avoid damaging your circuits.
For more information on connectors, visit this page.
Tools
Show more…
  1. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Back Cover: step 1, image 2 of 2
    Tool used on this step:
    Heavy-Duty Spudger
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 2, image 2 of 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Battery Disconnect: step 3, image 1 of 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 4, image 3 of 3
    Heavy-Duty Spudger
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Headphone Jack: step 5, image 1 of 2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Headphone Jack: step 5, image 2 of 2
    • Unscrew the two 3mm screws with the Phillips 000 screwdriver.
  6. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 6, image 1 of 1
    • Lift the black cable connector with the plastic opening tool to disconnect the cable from the device.
  7. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 7, image 1 of 1
    Heavy-Duty Spudger
    • Slide the flat end of heavy-duty spudger under the audio jack cover and lift up to remove the metal cover from the device.
  8. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: step 8, image 1 of 1
    • Insert the flat end of the heavy-duty spudger under the headphone jack and gently lift up to remove the headphone jack from the device.
6 other people completed this guide.
Amy Tsai
1,993 Reputation
2 Guides authored
Cal Poly, Team 6-26, Amido Winter 2015 Member of Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 3,677
