Samsung Galaxy Tab 2 7.0 Camera Replacement
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: step 1, image 1 of 1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: step 2, image 1 of 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: step 3, image 1 of 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: step 4, image 3 of 3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: step 5, image 1 of 1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
2 other people completed this guide.
Katija Tarailo
460 Reputation
3 Guides authored
IUPUI, Team S3-G1, Harley Spring 2017 Member of IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 667
