Samsung Galaxy Tab 3 10.1 Battery Replacement
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: step 1, image 2 of 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 2, image 2 of 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: step 3, image 1 of 3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: step 3, image 2 of 3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: step 3, image 3 of 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 4, image 2 of 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 5, image 1 of 3 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 5, image 2 of 3 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 5, image 3 of 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 7, image 1 of 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 7, image 2 of 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 3 10.1 Battery Replacement: step 8, image 2 of 2
    • Lift with a nylon spudger to remove the battery.
75 other people completed this guide.
Corey Brown
9,111 Reputation
11 Guides authored
7 Comments
Great, Thanks for the help. It was very useful.
nyhorseracing - Reply
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - Reply
brilliant ! worked extremely well !
Carmelo Aquilina - Reply
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - Reply
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - Reply
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 193
All Time: 45,222
