Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement
  1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: step 1, image 2 of 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: step 2, image 2 of 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Front-Facing Camera: step 3, image 1 of 1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  4. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
2 other people completed this guide.
Corey Brown
8,826 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 876
