Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement
  1. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear Case: step 1, image 2 of 2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 2, image 2 of 2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Battery: step 3, image 3 of 3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 4, image 2 of 2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 5, image 3 of 3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 6, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 7, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 7, image 2 of 2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement: step 8, image 2 of 2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 1 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 2 of 3 Samsung Galaxy Tab 3 10.1 Rear-Facing Camera Replacement, Rear-Facing Camera: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
Corey Brown
8,826 Reputation
11 Guides authored
One Comment
I have noticed a couple of things on this article, so I figured i'd put them here.
The disconnection of the ZIF Ribbon cables doesn't seem necessary for the repair at all, & the complete removal of the battery from the chassis is unnecessary as well.
The camera is a small, singular part that doesn't connect to anything else.
For safety's sake, I'd personally still recommend you disconnect the battery, to ensure there's no power flowing through the system, but complete removal is highly unnecessary.
oneiricNomad - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 734
