Samsung Galaxy Tab 3 8.0 Audio Jack Replacement
  1. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: step 1, image 1 of 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Battery - Open up the tablet: step 1, image 2 of 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: step 2, image 1 of 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Back Cover: step 2, image 2 of 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: step 3, image 1 of 2 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Battery: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Remove Battery: step 4, image 1 of 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Disconnect Audio Jack: step 5, image 1 of 1
    • Disconnect Audio Jack from Motherboard.
  6. Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: step 6, image 1 of 3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: step 6, image 2 of 3 Samsung Galaxy Tab 3 8.0 Audio Jack Replacement, Unscrew Audio Jack: step 6, image 3 of 3
    • Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
anthony gonzalez
313 Reputation
3 Guides authored
USF Tampa, Team 4-2, Brown Fall 2014 Member of USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Members
26 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,868
