Samsung Galaxy Tab 3 Lite Motherboard Replacement
  1. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: step 1, image 3 of 3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 2, image 3 of 3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: step 3, image 1 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: step 3, image 2 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
    • Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the battery ribbon cable.
    • Use the precision tweezers to remove the ribbon cable from the ZIF connector.
  5. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 5, image 2 of 2
  6. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 6, image 1 of 1
    • Remove the seven 4mm Phillips J000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 7, image 1 of 1
    • Use the plastic opening tool and gently pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 8, image 1 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 8, image 2 of 3 Samsung Galaxy Tab 3 Lite Motherboard Replacement: step 8, image 3 of 3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard off the case.
21 other people completed this guide.
Patricia Laird
927 Reputation
4 Guides authored
USF Tampa, Team 11-1, Cheng Spring 2016 Member of USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Members
12 Guides authored
3 Comments
Thank you friend!
nandoquoos2 - Reply
Nice guide, Done very well.
Keith Mullins - Reply
Ótimo guia. Esses tutoriais facilitam demais nossa vida. Sou fã! Parabéns
Amaury Souza - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 7,735
