Samsung Galaxy Tab 4 7.0 Camera Replacement
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: step 1, image 2 of 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 2, image 1 of 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 4, image 3 of 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 5, image 2 of 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: step 6, image 1 of 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: step 6, image 2 of 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 1 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 2 of 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: step 7, image 3 of 3
    Buy
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
9 other people completed this guide.
Aubrey Goodwin
2,700 Reputation
3 Guides authored
USF Tampa, Team 1-3, Remmell Fall 2015 Member of USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Members
12 Guides authored
3 Comments
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Reply
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Reply
टॅब पार्ट खरेदी करना है मुझको
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 4,301
